Activity Forums Adobe After Effects After Effects CC looping glitch
  • After Effects CC looping glitch
    Posted by Charlie Nancy on May 28, 2014 at 8:24 am
    I’m trying to loop a composition in After Effects CC (enable Time Remapping, add expression “loopOut()” ), and am getting the common problem of a blank keyframe flashing. Usually this is fixed by adding an extra keyframe one before the last keyframe, then either deleting the original last keyframe or setting its value to 0.
    This is no longer working and I’m not sure whether this is a CC thing, has anyone found any other solutions to this? No matter what I do, whatever the last keyframe is will always be blank.
    George Goodman replied 12 years, 3 months ago 2 Members · 1 Reply
  • George Goodman
    May 28, 2014 at 1:10 pm
    Which keyframe is it blank on? The keyframe representing the last frame or the one in which you tell it to start over?
    A couple things it could be just off hand:
    -Make sure that your keyframe says 1 not 0 when it’s starting over
    -Make sure the last and first keyframe have no spaces between them.
    -Make sure that you actually have something on the very first and very last frames.
    “|_ (°_0) _|”
    Sincerely,
    George
    http://www.vimeo.com/georgegoodman
    http://www.linkedin.com/in/georgefranklingoodman
