After effects cc 2019 doesn’t use all PC resources
Dear friends,
I have after effects cc 2019 running on dell precision t3610 with Xeon 1650 V3 @3.5 Ghz with 32 GB ram and Nvidia RTX 2080 (Win 10 X64). (All drivers are updated)
I created a composition with the following element inside :
– VCP ORB at 32bit and the megascan quixel spaceship model with element 3D
– Optical flares and couple lights (4)I enabled GPU acceleration in after effects but it preforms so slow and when I look to the task manager, I see that After effects use only about 20% at max of my CPU (about one core core -CPU 1-) and 4% of the GPU !!? when I render using media Encoder CC 2019 same thing it doesn’t use all gpu ressources neither CPU ressources (25 % average), I even used the BG render max but it go’s onlu up to 40% of CPU ??! :/
I searched every where on the internet but I didn’t find any answer to understand the reason of its low performance ?! Please help, I am loosing a lot of time when I use after effects because of this issue !
