Activity Forums Adobe After Effects After Effects CC 2018 won’t render past a certain time point.
  • After Effects CC 2018 won’t render past a certain time point.
    Posted by Niomi No on March 30, 2018 at 9:05 pm
    Hi all, I’m having a problem rendering in after effects despite it usually working perfectly.
    my problem:
    I recently finished my edit in After Effects and add continued to Composition > Add to render queue as usual. My settings are best settings (pretty sure it’s default) and my output module is quicktime (H.264) since it is an mp4 file. I then click render and it gets to 4.05 seconds and then pauses for around 30 seconds and continues to say render failed. I have tried multiple options and I even moved one of my clips that was in that time frame and rendered then and it still wouldn’t render, proving that it was not the clips issue.
    I have after effects on my acer (windows) laptop. Also, my composition settings are 1280 x 720 and the duration I set it to is a minute however the clips only came to 32 seconds.
    If I have missed any information out please tell me and I will reply back. Thank you and all help will be appreciated.
    Steve Bentley replied 8 years, 5 months ago 3 Members · 3 Replies
  • Jim Arco
    March 31, 2018 at 1:05 pm
    I have found that renders that fail at the exact same point are usually related to memory issues. Often times it is insufficient space on the destination drive.
    Jim
  • Steve Bentley
    March 31, 2018 at 6:15 pm
    The way some compressed files (like MP4) are encoded creates virtual frames (this is a gross oversimplification) . So if you are using these compressed files as source for your footage, AE can get stuck on these unusual frames.
    If you can try exporting the Mp4 from quicktime or some other conversions software into a non compressed format – like animation Best or AVI uncompressed, then use that as your source in AE and see if it will render past that point.
  • Steve Bentley
    March 31, 2018 at 6:39 pm
    Or it could just be the 2018 memory issue. Its finally become habit for us any time we see something odd in 2018 to just purge call caches and that solves the problem 50% of the time.
    There is an update for 2018 but we haven’t seen an improvement in the cache issue.
