Activity › Forums › Adobe After Effects › After Effects Can’t Open!
Posted by Ian Leo on February 15, 2011 at 12:55 pmThis is a BIG problem! Now, I can’t OPEN After Effects! When I try opening it, it says: After Effects Warning: Error parsing properties list. When I try opening it a second time, it says it has crashed! Help please, thank you! 🙂
Robert Hoisan replied 15 years, 7 months ago 3 Members · 6 Replies -
Robert Hoisan
February 15, 2011 at 1:41 pmAn xml file may be corupted in AE. Here is what i would do:
– update AE
If still not working
– back up the folder called 9.0 ( from…AppData\Roaming\Adobe\After Effects\9.0 folder)
– AFTER THE BACK UP delete the entire 9.0 folder.
– AE should open fine nowRobert Hoisan
Motion Graphics Artist -
Walter Soyka
February 15, 2011 at 2:36 pmTry restoring the default preferences. From Preferences [link] in the documentation:
To restore default preference settings, hold Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) while the application is starting. To also restore default keyboard shortcuts, Alt-click (Windows) or Option-click (Mac OS) the OK button.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Robert Hoisan
February 16, 2011 at 10:56 amHave you tried restoring the default preferences as Walter suggested?
If still doesn’t work you can find the 9.0 folder easy. Just type “%appdata%” without the quotes in search box on W7 or in Run on Xp. Then you go to Roaming\Adobe\After Effects and you will see the 9.0 folder.
REMEMBER: Make a copy of that folder first as backup and put it in some place safe just in case something goes wrong and you revers the process then delete it and try opening AE again.
See how it works,
Robert Hoisan
Ian Leo
February 18, 2011 at 1:15 pmThanks but it says I can’t delete the folder because it is in another program. I have nothing else opened but that folder. Please help, thanks! 🙂
Robert Hoisan
February 18, 2011 at 1:39 pmSee if there are AE sequences open. Ctrl+Alt+Esc and look for workin programs the task manager. Close any related to Adobe.
If doesn’t work, try rebooting your system.
And last resort a clean reinstall of AE.
Robert Hoisan
