Activity Forums Adobe After Effects after effects can’t continue, after effects has crashed, (0:42)
  • after effects can’t continue, after effects has crashed, (0:42)
    Posted by Jesmine Ng on March 23, 2009 at 5:19 pm
    I used AE CS3 for few months. It’s been using fine until these few day, when i drag a file or drag a fx to timeline, it come out the message,”after effects can’t continue, after effects has crashed, (0:42)”.
    I’ve tried :
    1. deleted the prefs file.
    2. updated Quicktime.
    3. deleted OpenGL.
    4. Remove the 3rd party video codec, eg: canopus
    5. Uninstall and reinstall the whole program.
    But, it’s still doesn’t work.
    Please help me! i only left 2 days to submit my work!
    Thank YOu!
    Roland R. kahlenberg replied 17 years, 6 months ago 3 Members · 4 Replies
  • Dino Muhic
    March 23, 2009 at 6:22 pm
    Which drivers did you update in the days before? Any changes to the system? Tried a system restore? WIN or MAC?
    What do you mean by saying “deleted OpenGL”?
    Did you run an update on After Effects?
    Do a RAM test (use the program “Memtest”) to check if your RAM is ok.
    Try defragmenting.
    This is what I came up. Don’t have more ideas. Sorry
    Dino Muhic – Media Producer
    VFX – Motion Graphics – Web-Design – Or just ART
    http://www.dinomuhic.com
  • Roland R. kahlenberg
    March 23, 2009 at 7:09 pm
    I’m with Dino on this in that this is a low level error.
    I would also look at CODECs and specific plugins. Do provide more info on your machine and details of the project.
    Do you get this error with a new, empty project?
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in Asia.
  • Jesmine Ng
    March 24, 2009 at 2:46 am
    I tried the suggestion which i found in other forum, saying that removed the OpenGL, and tried. But,it doesn’t work for my case.
    Previously, it really run smooth and fast for quite a long time.Until I installed Edius, but Edius doesn’t work in my PC, hence, i uninstall it. Since then, my AE CS3 crashed when i drag files in AE. Now, i only can use “copy and paste” or right click on the layer to add effects.
    I did clear all the possible canopus.Uninstall it, deleted all the canopus folder, deleted the registry key.And, I didn’t update any driver before.
    I’m using PC,winXP SP2.
    March 24, 2009 at 6:17 am
    Well, at least you know that Edius is the culprit. I’m pretty sure that the installation of Edius affected something in your OS in a drastic way. I would check with your Edius reseller.
    Also check ALL the settings for your graphics card. I would start with settings that were as plain as possible, ie. no hardware acceleration and a smaller resolution. Test AE with such a setting and then work your way up towards a more souped up setting. Sould AE still misbve with a basic setting for youou graphic card then there could be something else that Edius may have done – perhaps to your HD settings.
    HTH
    RoRK
