Activity › Forums › Adobe After Effects › After Effects Camera Movement Problem
  • After Effects Camera Movement Problem
    Posted by Trinh Nguyen on December 21, 2018 at 11:08 am
    I have an issue with camera movement.
    I have Element 3d that contains some objects, and I wanna to do a dolly shot so I used 2 keyframes that and changed the value of the X axis.
    Problem is the camera stayed still for 1 second before moving, when I check different views, the camera still moves exactly, but the active camera shows a different story… it just happened today, I haven’t met this issue before.
    Please help.
    Michael Szalapski replied 7 years, 9 months ago 3 Members · 2 Replies
  • Kalleheikki Kannisto
    December 22, 2018 at 7:53 am
    The first place to investigate would be the graph display of the position animation.
    Senior Graphic Designer
  • Michael Szalapski
    December 23, 2018 at 12:44 am
    Can we see a screenshot of the graph editor as Kalleheikki suggests or a screen recording demonstrating the issue?
    Also, what, exact, version number of After Effects are you running?
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
