Activity › Forums › Adobe After Effects › After effects cache on SSD
Posted by Zvi Twersky on May 29, 2014 at 6:48 pmIt’s known that to improve performance in After Effects you should move your disk cache off of your system drive to a fast drive. But lets say my system drive is the fastest drive (I just got an SSD for my system drive)… so is it logical to move my cache back to the default system drive?
Kiki Muchtar replied 11 years, 1 month ago 4 Members · 6 Replies -
Walter Soyka
May 29, 2014 at 7:39 pm[Zvi Twersky] “But lets say my system drive is the fastest drive (I just got an SSD for my system drive)… so is it logical to move my cache back to the default system drive?”
Yes, the cache should be on your fastest disk.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Zvi Twersky
May 29, 2014 at 8:02 pmThe capacity is 500GB and after installing everything, there is 218GB free. I DO want the SSD to be ny system drive for Windows now loads completely in 15 seconds and programs open with lightning speed.
Zvi Twersky
May 29, 2014 at 10:07 pmActually, I’ve thought of that idea and will definitely be trying it! Thanks.
Walter Soyka
May 30, 2014 at 1:35 amThis is really dependent on the kind of work you do, the kind of footage you use, etc. — but I really like the OS and apps on an SSD. The difference in overall responsiveness is very pleasantly surprising, and I am moving all my systems over to SSD boot drives.
But for disk-intensive projects, yes, running them from fast storage can be a major productivity boost. Sometimes I use solid state storage for full-res proxies, too.
Walter Soyka
Ericbowen
May 31, 2014 at 5:35 pmDue to how SSD drives bypass using the permanent erase write cycles on the MLC, the drive will slow down over time due to garbage filling on the drive that has been deleted and not cleaned up. The firmware of the SSD decides how efficiently the SSD cleans up the drive but the drive will still slow down eventually. The way to reset the drive is to wipe it normally with writing zeros. That is easy to do on a media or cache drive but not easy to do on the OS. I would not suggest using the OS SSD drive for media at all. AE cache is fine but not the media cache or media files. If you want those on an SSD then get a 2nd just for those.
Eric-ADK
Tech Manager
support@adkvideoediting.com -
Kiki Muchtar
July 28, 2015 at 3:47 pmHi Dave,
We deal with 2K editing—would 256GB SSD be enough for media cache storage?
Thanks.
Kiki
