Activity › Forums › Adobe After Effects › After Effects BMCC – Import
  • After Effects BMCC – Import
    Posted by Jim Sandstén on December 24, 2013 at 7:33 pm
    Hey guys, I would like to start with apologizing for any bad English (I’m from sweden)
    Now to my problem, I work with a BMCC 2.5 camera and with After Effects CC in post
    I’m trying to import a bunch of sequences into AE and I don’t get the option to create a Sequence from the .DNG files (pic)
    Now I have to enter each folder (sequence) every time I want to import a sequence and do this over and over again
    (i can only import 1 folder each import so it takes a huge amout of time)
    and when i try and drag and drop from Finder into AE it says
    Thanks in advance and merry christmas to you all!
    Jim Sandstén replied 12 years, 9 months ago 3 Members · 3 Replies
  • Erik Waluska
    December 24, 2013 at 11:24 pm
    Hey Jim, You might check out this thread, and then check out the immigration script that Walter recommended.
    Erik Waluska
    EAWmedia
  • Todd Kopriva
    December 25, 2013 at 3:35 am
    Be sure that you don’t have the audio files selected when you’re trying to import an image sequence. That appears to be your problem.
    After Effects team blog
  • Jim Sandstén
    December 25, 2013 at 1:29 pm
    The multiple import has worked with audio a while ago, and removing all the audio files in the folders is also time consuming but thanks for the advise
