Activity › Forums › Adobe After Effects › After Effects Benchmark Test
Posted by Ngo Truong an on March 2, 2009 at 1:10 pmHello,
i´m looking for an Benchmark Test for AE.
Can somebody give me a tip.Thanks
Tim Kocher replied 14 years, 6 months ago 4 Members · 10 Replies -
Kevin Camp
March 2, 2009 at 5:15 pmif you are looking for a project to run your own tests, here’s an older one, but it should still work for newer ae versions:
https://www.media-motion.tv/aebenchmarks.html
if you are looking for some benchmarks of systems using that project file, try googling after effects total benchmark. if you are trying to compare macs, here is a link to a page with some results for various macpro systems from about a year ago:
https://www.barefeats.com/harper.html
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Rob Chisholm
June 23, 2011 at 4:03 pmHello NGO AN
Here is a link with some information on benchmarks that i have done, feel free to join in email me your results.
https://www.asahiart.co.uk/Pages/Bench_Test_After_Effects_CS3_Power_mac_dual_2.7_5Gb_Ram.html
Rob
Tim Kocher
February 15, 2012 at 5:16 amI did your benchmark (as well as Brian Maffit’s … that one is REALLY old!) … and yours took 20 seconds … and I was web browsing, lol. Not sure how I stack up against other modern PC builds, but this seems pretty good to me. I’m running a OC’d Sandybridge 3.4ghz (4.6ghz stable) with 16GB’s RAM (hope to go to 32GB soon), RAID0 Caviar Blacks, SSD OS and App drive.
How can I see other’s results?
Tim -
Rob Chisholm
February 15, 2012 at 10:46 amHi Tim,
If you go to this link your see results
If you email me your results and spec I post them on the site. (email at bottom of the page)
Rob
Tim Kocher
February 15, 2012 at 8:34 pmHi Rob:
Yes, that’s where I went to get the benchmark project file. However, I do not see a list of results anywhere. Can you point me in the right direction?
I’ll email you my specs and results in the meantime.
Best,
Tim -
Rob Chisholm
February 15, 2012 at 9:31 pmHi Tim,
This is the page your looking for
https://www.asahiart.co.uk/Pages/Bench_Test_After_Effects_CS3__2.7_5Gb_Ram.html
If using the other link
I posted click on the “continue” bottom right.
Hope that makes sense.
Regards Rob
Tim Kocher
February 15, 2012 at 9:44 pmRob,
Ok, right, I saw that page as well (and unless I’m really dense, and just missing it …) I don’t see a list of results. I just see your initial results from a couple of different setups.
Best,
Tim -
Rob Chisholm
February 15, 2012 at 10:16 pmHi Tim,
Total results I have had from another person at this moment in time Feb 2012 is one “8 core G5”
The other result on the page is from my own mac G5.
So this is the list as it stands.
Regards Rob
Tim Kocher
February 15, 2012 at 11:26 pmAhhhh, gotcha … didn’t realize I was seeing all that there was to be seen. 🙂
Cheers,
Tim
