Activity › Forums › Adobe After Effects › After Effects Before Professional Color Correction?
  • After Effects Before Professional Color Correction?
    Posted by Liz Parham on October 7, 2013 at 6:27 pm
    I’m editing a feature-length documentary/pretty new to After Effects but I’ve figured out how to blur out the faces of multiple people who we weren’t able to get releases from. I was wondering if I were to import the shots back into final cut would this create trouble down the line when we plan to use any professional color correction services? A co-worker brought up a point that the cc ppl would want the video to have the least amount of manipulation? Is there a way to export the AE files as layers similar to a photoshop file so we can turn them on/off if needed?
    Liz Parham replied 12 years, 11 months ago 3 Members · 5 Replies
  • Todd Kopriva
    October 7, 2013 at 9:46 pm
    This kind of work is not going to be a problem for the colorist(s). If you were adjusting colors in After Effects, that would be a different matter.
    Just make sure that you’re rendering and exporting from After Effects to a format and codec that lose as little information as possible. Compression artifacts are a nightmare for coloring work.
    After Effects team blog
  • Liz Parham
    October 7, 2013 at 9:55 pm
    Thanks for the response, Dave. We’ve used ProRes422 for all of our footage. Do you recommend doing this in After Effects or is there a different program I should try? I’ve heard some things about Mocha. Just trying to keep down costs so we don’t have to send it to a post house.
  • Todd Kopriva
    October 7, 2013 at 10:22 pm
    Blurring faces is easy in After Effects.
    I show a few ways in these videos of selectively applying an effect to a tracked region:
    https://www.video2brain.com/en/lessons/removing-a-logo-from-a-moving-image
    https://tv.adobe.com/watch/learn-by-video/adobe-after-effects-cs5-motion-tracking-and-rotoscoping/
    https://www.video2brain.com/en/lessons/isolating-a-subject-with-roto-brush
  • Ross Shain
    October 8, 2013 at 3:11 pm
    mocha AE comes bundled with Adobe After Effects CC. However, if you are cutting in Final Cut Pro X, than you may also want to check out SliceX powered by mocha from CoreMelt.com
    This is a $99 plug-in that does the shape masking, tracking and blurring all within the FCPX timeline. For long form project cut on FCPX, this could be the most efficient way to blur faces.
    Hope this helps,
    Ross
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
  • Liz Parham
    October 8, 2013 at 3:18 pm
    Thanks, Todd! Your videos were really helpful.
