Activity › Forums › Adobe After Effects › After effects auto deletes ram previews
Posted by Hassaan Maalik on January 30, 2012 at 11:20 amhi im using after effect cs5 for about half a year and today im facing this problem that after effect is not storing frames
Ivan Ferenczsak replied 11 years ago 8 Members · 11 Replies -
Michael Szalapski
January 30, 2012 at 5:14 pmPlease describe your issue in more detail.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Cassius Marques
January 30, 2012 at 8:32 pmIs it not storing or is it deleting one as you try to preview another?
You’re probably just running out of RAM… check your processes and see if AE is taking all your system has for it.
Hassaan Maalik
January 31, 2012 at 5:18 amOnce I stop playing the ram preview, it deletes the whole thing and I have to rerender if I want to watch the preview. Any ideas? Is it just a checkbox hidden somewhere?
Roland R. kahlenberg
January 31, 2012 at 10:00 amThe range of frames that are cached to RAM are depicted within a green line at the top of the Timeline. Occasionally, you will see a blue line which indicates that the underlying frames are cached to the HD.
Upon completing a RAM Preview, you should see the green line. If you made changes to a layer or change the hierarchy of layers in the Timeline, then AE will discharge the contents of the RAM.
HTH
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
Hassaan Maalik
January 31, 2012 at 12:19 pmram previews immediately deleted by itself without any changes in comp by me
Michael Szalapski
January 31, 2012 at 5:06 pmTry trashing your AE prefs and seeing if that fixes it.
Have you done any changes to your system recently? Installed any software, done any updates, etc?
– The Great Szalam
Tom Gomez
August 10, 2012 at 5:39 amDid you ever find a solution to this? It’s happening to me and driving me crazy!
YOU can help save TimeSpace. Join the Chronos Protectorate!https://www.95ers.com
https://www.SpaceAceMedia.com -
David Cabestany
February 2, 2013 at 12:27 amI have the same issue in CS6, with 32gb of ram, did anyone ever found the solution?
Tom Gomez
September 7, 2013 at 4:10 amI’ve never really understood the RAM caching. Sometimes it vanishes without me doing anything. And even more annoying, sometimes it WILL NOT vanish when I DO change something… then when I play back, some frames are rendered right, and some frames play back as if I hadn’t made the change…
