Activity Forums Adobe After Effects After Effects and music ?
  • After Effects and music ?
    Posted by Tobias Schrenk on November 26, 2008 at 3:56 pm
    Hello,
    I have to visualize music for a project. I want to make the animation in After Effects (visualization schould be done with shapes).
    I know that After Effects plays the music when I watch the RAM preview. But is there a possibility to play the music the whole time ? I want to synchronize the music with the movement of the shapes.
    Thanks a lot for your help
    Adriano Moraes replied 17 years, 10 months ago 3 Members · 3 Replies
  • Tobias Schrenk
    November 26, 2008 at 9:16 pm
    I think I haven´t writte it clear enough what I mean.
    I want to work in the timeline, animate the shapes and while i work at the shapes i want to put them syncron to the parts of the music where it fits.
    How I would for example work in Premiere Pro. Scroll through the footage and listen to the music simultaneously.
    It´s just when I am looking through the animation it´s not possible to listen to the sound.
  • Jason Milligan
    November 26, 2008 at 10:55 pm
    As Dave has pointed out, you can’t “play” without RAM previewing, but these tips may be helpful to you:
    You can scrub audio if you hold down Command/Ctrl while dragging the playhead.
    You can open the waveform and sync to its peaks and valleys.
  • Adriano Moraes
    November 27, 2008 at 12:33 pm
    There´s another thing I usually do ti give me more of a visual reference.
    Before I start animating I select the sound layer on the timeline and play it (pressing ” , ” on the keypad) and I keep hitin’ ” * ” on the same keypad to add markers to the layer whenever I feel necessary (say according to the beat or some special moments).
    That along with Jason´s tips can help a lot. Helps me all the time. But don´t forget, it´s a bit of a pain down in there anyway.
    It takes time and pacience. So good luck.
    Cheers.
    ninguem.
