Activity › Forums › AJA Video Systems › After Effects and FCP 5 with IO
  • After Effects and FCP 5 with IO
    Posted by Andy Edwards on August 27, 2005 at 7:33 pm
    I working on some graphics in After Effects 6.5 and previewing with the IO on a external sony monitor. After I render my comp, I fire up FCP 5 to check my graphics in the sequence. On FCP start up I get an error stating another device is using the video output.
    Is there a conflict with the IO and using two different appliations? The only way a can stop this error is close AE, then fire up FCP. Not to much of a problem, but I would like to keep the projects open on both apps. Is there a option to change set ups in the control panel?
    system details:
    G5 dual 2 ghz
    3 gigs ram
    Tiger 10.4.2
    FCP 5.02
    AJA IO Firm ware v2 2.0
    Andy
    Tony! Hulette replied 21 years, 1 month ago 2 Members · 1 Reply
  • Tony! Hulette
    August 27, 2005 at 10:51 pm
    Try clicking on the desktop before switching to a different application that also uses the Io’s video outputs.
    Tony!
