Activity › Forums › Maxon Cinema 4D › After Effects and Cinema 4D lighting?
Posted by Dan North on August 14, 2019 at 8:59 amHello there
I’m a long time Maya user, but due to Cinema and AE working so well together I thought it was time to jump onto the Cinema 4D train.
I have a paper cut scene in After Effects, and have lit it with lights in AE.
It gives it a nice and stylized look.
However I also want to add some 3D elements to the scene – is there a smart way to “re-build the scene” in cinema so it matches my AE scene and the lighting?
Any direction would be much appreciated.Cheers Dan
Corrado Carlevaro replied 7 years ago 2 Members · 6 Replies -
Dan North
August 20, 2019 at 8:35 pmThanks a lot Corrado.
Didn’t know it would bring in the whole scene with lights etc.I’m making a “paper cut” world with flat colors on shape layers and have set up lights in After effects.
I want to add a train driving through the world, so it’s basically just a sequence of the whole AE project that is “3D”.
Would you render in cinema and import in AE, or what is the smartest way to get it back and mixed with the rest in AE again after it has been through Cinema?Any direction would be much appreciated
Cheers, Dan
Corrado Carlevaro
August 21, 2019 at 8:27 am1. why not doing everything in C4D (flat shapes and train and everything)?
2. Render the train in C4D (where you need in any case your flat shapes to use as alpha masks when the train is passing behind them) and then compose in AE
2. Using Cineware for “seamless integration of 3D assets in After Effects compositions”, which I never used -
Dan North
August 21, 2019 at 10:10 am1. The look I get in After effects, the “paper cut” look with shape layers and 3D and adding point lights behind windows etc, gives a stylized and cute and look. It would be awesome to do in Cinema if it can “mirror” the same look.
I tried a test where I had 2 shape layers and a point light that I exported to Cinema and got the same look.However my large scene I working on, with several point lights and Illustrator files with layers (so I one Illustrator file with my landscape in different layers for easy tweak) – when exporting to Cinema, seems like the Illustrator shapes don’t get exported in layers as in After Effects?
2. Good point with the train – and the scene would make sense to re-create in Cinema so it will interact with the light . I see what you mean.
(My thought was first to do it in AE, it moving around as a 3D layer within the other 3D shape layers so I would be able to use the other shapes to “hide” it.
but VERY heavy slow scene ????Thanks a bunch for direction.
Best, Dan -
Dan North
August 21, 2019 at 6:49 pmBtw, I’n after effects I’m using this look:
https://www.shutterstock.com/da/image-vector/winter-snow-urban-countryside-landscape-city-535531183?id=535531183&rid=3071597
(hope it’s ok I link to it, it’s just to show the “style”)
and when using a point lights in the window and tweaking the colors, I can turn it into night scenes and make it look cute.How do I re-create the same look in Cinema ?
Best, Dan -
Corrado Carlevaro
August 23, 2019 at 12:52 amI have to admit I use AE for 2D projects, but sure you can have much more flexibility, possibilities and ease creating a “2D look” in Cinema, if you are not using specific compositing techniques (lot of blending modes, videos, pictures, illustrator files where AE is much better suited).
Your example looks like a perfect task for Cinema
