Activity › Forums › Adobe After Effects › After Effects and 60 frames a second
  • After Effects and 60 frames a second
    Posted by Nick Degner on December 20, 2005 at 7:38 pm
    We created a High Def (1280 x 720) animation and the final output is supposed to be a 60 frames a second. We load the targa stack in After Effects and set it to 60 frames a second and export movie to a quicktime movie to be inported into the final video. When the final the quicktime is exported we noticed that every other frame is exactly the same thus making the animation look chunky. Does anyone know what is the trouble? Thanks
    Bill Clotz replied 20 years, 9 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    December 20, 2005 at 11:08 pm
    Have you set your project settings to 59.94? Set your comp to 59.94? When you move through the timeline frame by frame does each frame repeat?
  • Bill Clotz
    December 20, 2005 at 11:18 pm
    Make sure you set the actual image sequence to 60fps. You have to rightclick it and go through interpret footage. I think they default to 30fps, so that would cause the problem you are describing.
