Activity › Forums › Adobe After Effects › After effects and 3d max merging…correct way?
  • After effects and 3d max merging…correct way?
    Posted by Ricky Milling on June 20, 2008 at 11:34 am
    I have created a tank in 3d max and filmed footage of someone looking around a corner down a street and ducking back in before looking again, i was wondering what would be the best way to combine them, as for some shots the entire of the tank wont be in shot as it is covered by the wall and parked cars in front. the secene ends with the tank rolling past the entrance to the alley way.
    I was just wondered which would be the best option take the footage from AE and put in in MAX or vice verse, can anyone please help and give some advice as it been driving me nuts about how togo about it properly.
    Thank you in advance
    Ricky
    Mohammad Taghi karimi replied 18 years, 3 months ago 3 Members · 2 Replies
  • Mike Park
    June 20, 2008 at 12:54 pm
    In my opinion, it is usually better to take a frame of your live action footage into 3d max and use it as a reference or background for setting up the 3d max camera. Once you match the camera position and orientation, you render out your cg elements with alpha channels and import them into afx. If you are using footage with the camera locked off or still on a tripod, you can create masks from your footage to superimpose over the cg elements and really place them into your scene. If you shot the footage freehand or if the camera moves, you have a whole new set of problems to deal with.
    Hope this helps
  • Mohammad Taghi karimi
    June 21, 2008 at 9:51 am
    the very useful answer is
    go and buy andrew kramer the bullet dvd coz its a very nice tutorial
    about merging 3d with after effects
    its a best dvds for matching 3d with ae i ever seen
    Just Try To Best Until You Death
