Activity › Forums › Adobe After Effects › after effects advanced 3d crash in AE 7
Posted by Ben The camera guy on July 2, 2006 at 4:06 amhi everyone,
i had a AE7 project that was working great. I go to open it one day and I get an error message after effects error: crash occured while invoking rendering plug-in “advanced 3d””…I’m using Powermac g5 Quad, does anyone know what is going on? I am so scared I can’t get to my project! plase help me… thanks…Michael Duff replied 20 years, 1 month ago 4 Members · 6 Replies -
Ben The camera guy
July 2, 2006 at 2:03 pmoh, and btw, when I switch the comp to “standard 3d,” the program crashed but the error message reads “standard 3d” not “advanced 3d”…
Serge Hamad
July 2, 2006 at 3:40 pmHi,
Did you try trashing your prefs file?
I hope this may help.
Salut.
Serge“InvigoMany” Available here:
https://www.nyc-visual.com -
Ben The camera guy
July 2, 2006 at 4:18 pmI tried this by deleting the two prefrences file inthe “library” section of the AE section of my HDD. I was returned to the original AE7 layout, but when I loaded my project, the program crashed…the program also crashes when I load my project onto my laptop…what could I be doing that would cause a crash like this?
~Ben the Camera Guy
Avid, Final Cut, and all the rest… -
Serge Hamad
July 2, 2006 at 5:02 pmHi,
Unfortunately it sounds that your project is corrupt. Try to import it in a new ae project and see if this works.
You could send me the project without any media files if you want. (serge_01 at msn dot com)Salut.
Serge“InvigoManny” Available here:
Yuno Kim
July 3, 2006 at 7:21 amHi.
Turn on the CAPS Lock before start AE, and then delete effect(Advanced 3D). And turn off CAPS lock.
It will work.
There is only one, AE!
Michael Duff
July 17, 2006 at 1:14 amhi there – I’m getting the same problem now, did you find a solution?
“Turn on the CAPS Lock before start AE, and then delete effect(Advanced 3D)” – the advanced 3D effect is a render plug-in, so you can’t just delete it – due to the design of my project I need it to be in Advanced 3d and not standard 3d….. i’ve tried changing the shadow map size, still no good.
any other pieces of advice?
Michael Duff –
Bearcage Productions, Australia
