Activity Forums Adobe After Effects After Effects added extra pixels on my transparent FLV
  • After Effects added extra pixels on my transparent FLV
    Posted by Rob Dupuis on February 12, 2010 at 6:56 am
    Hey, I’ve noticed today that After Effects adds extra pixels to my FLV renders. My render is suppose to be 281 x 230, that’s what all my settings are set at. And only when I render as a transparent FLV, my render becomes 300 x 234. So I started looking back at my other renders of the same format and I noticed they all had extra pixels put in. Anybody else ever run into this problem?
    I’m running Windows Vista 64bit with Adobe CS4. My colleague tested the same file on his machine (Mac running Windows Vista) and the same problem happened.
    My final comp is set at 281 x 230. Any suggestions?
    Thanks.
    RD
    Onyx Lee replied 13 years, 1 month ago 6 Members · 11 Replies
  • 11 Replies
  • Rob Dupuis
    February 12, 2010 at 2:34 pm
    I posted this from home last night, now that I’m at work I can get the actual numbers:
    Comp size: 238×183; flv with alpha
    rendered size: 240×192; flv with alpha
    Why would After Effects add 2 pixels to the width and 9 pixels to the height?
  • Ryan Mcafee
    February 12, 2010 at 2:37 pm
    Could it be in the settings some kind of locked aspect ratio setting?
    Ryan McAfee
    Moon Community Access Television
    http://www.MCA-TV.com
  • Rob Dupuis
    February 12, 2010 at 4:55 pm
    Just re-checked everything again and I can’t find anything of the sorts. Thanks though
  • Jonathan Pannacciò
    February 13, 2010 at 12:18 pm
    FLV is a square pixel format, if you work a differnt pixel ratio the render process convert the file, check your comp_setting and set ratio to square pixel. you can olso render a mov_ animation file, then use adobe media encoder to create any kind of compression you want from master.
    good luck
    cheers
    *^_^*
  • Rob Dupuis
    February 16, 2010 at 3:07 pm
    Thanks for the tip. I’ve checked my Pixel Aspect Ratio and it’s set at Square Pixels. I’ve also tried to render a MOV file and use Media Encoder, still the same results. And this is happening on 2 separate machines.
    Thanks tho.
  • Rob Dupuis
    February 17, 2010 at 6:47 am
    Am I really the only one with this issue? Cause it’s pretty easy to reproduce.. If I’m using anything other than 16px X 16px blocks, it rounds it up (or down) to fit this size. Very weird.
    Any help at all?
  • Rob Dupuis
    February 24, 2010 at 3:21 pm
    Am I seriously the only one with this issue????
  • Brian Bryant
    March 19, 2010 at 5:35 pm
    You are not the only one. I also find that creating FLV files can be a true pain. For no reason at all they love to crop videos undesirably.
    Even if you create a square FLV from a square MOV file, it crops the video on the sides and adds a black frame to the left and right.
  • Rob Dupuis
    April 5, 2010 at 8:06 pm
    So I’ve recreated the issue, and posted a video on youtube at https://www.youtube.com/watch?v=4SxZkKVRvIQ
    Please follow the link for an HD version where you can see the actual numbers I’ve used.
    It’s also effecting all my FLVs, and not just the ones with an alpha.
    Any ideas?
  • Daniel Guerra
    March 27, 2012 at 1:53 pm
    I know it’s been a long time since you wrote this post, but I’ve encountered the same problem as you and cannot seem to find a solution anywhere on the Web.
    Have you been able to solve it? And if so, how?
    Any help would be greatly appreciated 🙂
