Activity › Forums › Adobe After Effects › After Effects 3D Problem
Posted by Peter Dunphy on June 16, 2005 at 2:32 pmHi.
Working in After Effects at the moment, creating a 3D world, and I’m having problems with the 3D layers interacting, namely, they’re not staying hidden when they should.
Has anyone encountered this problem before, is it fixable? or is After Effects’ 3D capabalities not up to this?
Thanks in advance
Steve Roberts replied 21 years, 3 months ago 6 Members · 7 Replies -
Erik Cantu
June 16, 2005 at 4:47 pmhave you tried changing the layer orders? or pre-comping some of the different elements?
Filip Vandueren
June 16, 2005 at 10:48 pmMake sure you use the advanced 3d renderer, you can set it in the Composition settings, advanced tab
Colin Braley
June 17, 2005 at 2:00 amMake sure your 3d layers are all toghether in the timeline, if they are separated by a 2d layer sometimes the render looks messed up. I remember reading something in that manual about 3d layers that are separated by 2d layers don’t interact correctly.
~Colin Braley -
Peter Dunphy
June 17, 2005 at 11:05 amLooks like that advanced tab worked… genius thanks lads, you’ve enabled me to m
Chris Smith
June 17, 2005 at 2:04 pmGeez, man, I gotta ask: Why not do this in a 3D app? Are you testing your patience with AE 🙂
Chris Smith
https://www.sugarfilmproduction.com -
Peter Dunphy
June 17, 2005 at 2:15 pmTwo reasons really,
1. Have no knowledge of 3D applications, come from a 2D background.
2. Mucking around with after effects seems to create something unique in a 3D world. Ok I’m not going to be create proper textures and lighting effects… but the end result strikes a chord with me. Just trying to push the program which I spend most of my time with to the limit, thought I may have reached it yesterday, but with the advice of this board, it’s going even further… ps adobe rules!
Regards
CP -
Steve Roberts
June 17, 2005 at 2:38 pmI’d join Chris and advise you to spend the $100 for Cinema 4D CE+ and learn it before you have to do something that AE can’t do … on a deadline.
At least learn how to extrude along a path to make those growing tubes and ribbons. It’s dead-easy in C4D.
My point is, actually, if you want to be an AE artist, fine. But if you want to be a motion graphics artist, you’ll need a 3D app sooner or later. Better to hop on the learning curve now.
If you want to see discussions on which app to choose, search the COW for “cinema” — it’ll lead to discussions of a bunch of 3D apps.
Steve
