Activity Forums Adobe After Effects After Effects 3D Position only rotate
  • After Effects 3D Position only rotate
    Posted by Jim Johnston on January 28, 2017 at 3:29 pm
    Hi all,
    trying to figure out a way to rotate layers around an axis in 3d without the actual layer itself rotating, but only taking in positional data from a null. Is there a way to do this? I guess I need to bake the positional data of the 3d null out from the rotation attribute so I can use it to parent the layer.
    Imagine a solar system and I need to rotate flat planets around a sun in 3D so the faces of the planets are always facing the camera.
    Any hints will be appreciated.
    Jim Johnston replied 9 years, 7 months ago 2 Members · 4 Replies
  • Roei Tzoref
    January 28, 2017 at 4:21 pm
    apply this expression to the rotation property of your layer:
    -parent.rotation
    now the layer will not take into account the parented rotation information.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Jim Johnston
    January 28, 2017 at 4:38 pm
    Thanks very simple, just invert the parameter!
    I used:
    -parent.transform.xRotation
    Cheers
    △ As Above | So Below ▽
  • Jim Johnston
    January 28, 2017 at 7:29 pm
    Ok, when I try rotating more than one axis, this technique falls apart. Just inverting the rotation against the null doesn’t seem to work.. I guess the math isnt right!
    Any ideas?
    Cheers
  • Jim Johnston
    January 28, 2017 at 9:53 pm
    Fantastic, found this incredible post here
    https://forums.creativecow.net/thread/227/24188#27547
    Apply this expression to your orientation and it will nullify any 3D rotation inherited from the parent.
    Not entirely sure how it works though!
    u = fromWorldVec([1,0,0]);
    v = fromWorldVec([0,1,0]);
    w = fromWorldVec([0,0,1]);
    sinb = clamp(w[0],-1,1);
    b = Math.asin(sinb);
    cosb = Math.cos(b);
    if (Math.abs(cosb) > .0005){
    c = -Math.atan2(v[0],u[0]);
    a = -Math.atan2(w[1],w[2]);
    }else{
    a = (sinb < 0 ? -1 : 1)*Math.atan2(u[1],v[1]);
    c = 0;
    [radiansToDegrees(a),radiansToDegrees(b),radiansToDegrees(c)]
    credit to Dan Ebberts
    Cheers
