Activity Forums Adobe After Effects After effects : 3D Elments
  • After effects : 3D Elments
    Posted by Hanna Lee on July 9, 2014 at 5:50 pm
    i have the new after effects that has 3d camera track.
    i am having some issues with element which is when i try and add an object from video co pilot it stays invisible because i have a 3d camera below , if i uncheck the 3d camera then the ( object ) is visible pleaese help.
    i also tried to add new camera from , layer / new / camera then the ( object ) is shown but when i drag it all my other 3d objects gets moved away or disorted or disturbed by it please advise urgent.
    Hanna Lee replied 12 years, 1 month ago 3 Members · 17 Replies
  • 17 Replies
  • Hanna Lee
    July 9, 2014 at 6:09 pm
    oh also if i may add to this post i forgot to menshion when i move the time line of a video left – right the object disappears at the end of the corners how come.
    say i drag the time line to the left , the ( object ) say a box soon as it reaches the end of the ( solid ) it disappears like it gets masked away i want to remove this so i can have the ( object seen at all times thanks.
  • Walter Soyka
    July 9, 2014 at 6:12 pm
    Element should be applied to a 2D layer, not a 3D layer.
    If that’s not your problem, some screenshots showing your problem, some Element parameters, and your entire Ae UI will be most helpful.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Hanna Lee
    July 9, 2014 at 7:41 pm
    here is the video i made sir youtube link below.
    https://www.youtube.com/watch?v=uSjZ1WZ4ET4&feature=youtu.be
    their are two things am tring to archive sir.
    1: after i have added 3d text from ( 3d camera tracker ) i wish to add 3d objects to my scene from ( video co-pilot ) am struggeling so far nothing seems to help stuck at this point.
    what i tried so far
    just to let you know i have 3d camera tracker text already
    now i want to add 3d object or text from video co pilot
    i create a ( solid ) then , click the element button , i add my ( objects ) then after am back in after effects my object is not visible , the only way to make it visible is to uncheck the 3dcamera below or add a new camera above then it becomes visible then again my current 3d text gets disturbed by it and this is becoming a big problem for me sir.
  • Walter Soyka
    July 9, 2014 at 8:07 pm
    Check out this tutorial:
    https://www.videocopilot.net/tutorial/3d_truck_compositing/
    Walter Soyka
  • Hanna Lee
    July 9, 2014 at 8:45 pm
    i tried doing all whats shown in video still i have problem with post 1
  • Michael Szalapski
    July 9, 2014 at 9:18 pm
    If you can’t see your model with the camera in the scene, then the camera is not pointed at the object.
    If you’ll watch the tutorial that Walter linked, the guy moves his AE scene so that the camera is pointing towards the original center.
    Alternatively, move your Element emitter to an area that the camera is pointing at. Use AE’s camera tracker tool to create a null somewhere on the ground and then have the Element emitter be positioned there.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Hanna Lee
    July 9, 2014 at 11:14 pm
    can you come in my pc via team viewer sir if you shown me once i will learn quick, am a quick learner only need to se it done by pro like you gents please kindly can you provide help over remote desktop sir.
  • Hanna Lee
    July 9, 2014 at 11:18 pm
    can you please come to my pc via team viewer i will wait for you
    please download this 5mb team viewer and enter my id and pass
    https://www.teamviewer.com/en/index.aspx
    my user id is 558 391 689
    password 9825
    anybody is welcome to help me please
    please i wasted whole 4 days trying to learn i had no choice but to register on this forum to get help from you gents i am hoping to se some results sometime soon please guys.
  • Walter Soyka
    July 10, 2014 at 1:49 pm
    [hanna lee] “i tried doing all whats shown in video still i have problem with post 1”
    Have you created track nulls from the 3D camera track? This will give you the positional data you need to place the 3D object in your 3D scene.
    Also, I noticed in your video that you’re trying to move the model by adjusting the Element layer directly. You can’t do that. You need to manipulate position and scale within Element’s controls.
    Maybe you should start here:
    https://www.videocopilot.net/help/element/tutorial/basic/getting_started/
    Walter Soyka
  • Hanna Lee
    July 10, 2014 at 7:16 pm
    problem starts when having 2 camera in project what to do from here tho
