Activity Forums Adobe After Effects After Effects 3d – anchoring objects
  • After Effects 3d – anchoring objects
    Posted by Tiffany Pippin on December 2, 2013 at 4:33 pm
    I have imported a composition from illustrator. I tried to edit the original after import, which works fine when I’m editing a layer. however, when I try to add a layer, the new layer doesn’t show up. Am I missing a step? Also, since I couldn’t view my new layers, I decided to add a new text and shape layer in their place. However, they won’t stay put like the rest of the composition when I use the camera layer…they move with the camera. What can I do to fix this problem? Thanks!
    Tiffany Pippin replied 12 years, 9 months ago 3 Members · 4 Replies
  • Todd Kopriva
    December 2, 2013 at 8:31 pm
    Reloading footage does not add layers from Illustrator (or Photoshop) files. You need to import a file that has the number of layers that you’ll be using. Sometimes, I add dummy layers in Illustrator or Photoshop before importing into After Effects if I think that I’ll be adding new layers later.
    That advice is given in After Effects Help, here:
    https://helpx.adobe.com/en/after-effects/using/preparing-importing-still-images.html#preparing_and_importing_photoshop_files
    After Effects team blog
  • Frank Feijen
    December 6, 2013 at 8:05 am
    Regarding the ‘moving-with-the-camera’: did you swith the new layers to 3D?
  • Tiffany Pippin
    December 6, 2013 at 3:10 pm
    Thank you…I will remember that in the future!
  • Tiffany Pippin
    December 6, 2013 at 3:22 pm
    Yes, the new layers were on 3D, and I tried switching them off and on several times to get a response. Just wondering if one would need to add the new layer before adding the camera layer?
