Activity Forums Adobe After Effects After Effects
  • After Effects
    Posted by Suraj Shah on May 2, 2018 at 9:00 pm
    I am trying to understand how the speed walking effect at 15 seconds in the following video is constructed:
    https://www.youtube.com/watch?v=X2PuO2G1v6w&t=15s
    I believe it is done in after effects but I cannot fully figure it out as the people in the video are still…
    Any help would be appreciate, including youtube tutorials if you have come across these before.
    Many thanks
    S
    Steve Bentley replied 8 years, 4 months ago 3 Members · 3 Replies
  • Steve Bentley
    May 2, 2018 at 10:15 pm
    That’s just a time ramp on the footage and lots of blur. (motion blur can hide infinite sins)
    Option 1)
    The environment (including the walkway) may be CG (I think I can see the poly facets, but that may be chain link of the railing)
    When we do these kinds of shots, we will do a VR movie of each actor in the shot – a spin around so we have a frame of every angle of them. Then we time warp the footage of the people who have been rendered and use that as a texture on flat cards in the CG world so they appear to face the right way even though the camera is moving around them – the frame is picked based on camera angle and the card always faces camera. So yes, stills of a sort, and certainly architectural “cards” but with the moving texture it can seem like they have volume. Its kind of a reverse bullet-time.
    Option2)
    The other option is that its real and simply sped up. Did they tell everyone to stay still while the camera person walked the path? This would work. A few people move a little.
    I think this is more probable but because they have so much of the archi- previz in the video they may have used part of the animated selling package before the place was built.
  • Derek Bavin
    May 3, 2018 at 6:05 pm
    If you google Hyperlapse you can find that this trick is fairly simple. The camera takes a still photo, moves slightly forward, and takes another still photo.
  • Steve Bentley
    May 3, 2018 at 8:16 pm
    Re hyperlapse: I don’t think that’s the case here. Hyperlapse tends to add distortion to the images as it tries to line up objects from one image to the other and I don’t see any of that here. But the bigger tell is that because hyperlapse is brought to bear on a number of stills taken at different times (usually farther apart in time than an equivalent running video of a tour) the people move chaotically or even disappear.
    A simple radial blur (set to zoom) on sped up footage of a walkthrough would get you there. If you have the choice, just get your crowd to hold still while you walk the camera through the shot – even they aren’t perfectly still the shot will be so chaotic you wont’ notice it. There is a Seal music video that did this sort of thing. (in Paris I think)
