Activity › Forums › Adobe After Effects › After Effects
  • After Effects
    Posted by Erik Heffelfinger on March 9, 2017 at 6:17 am
    I’m trying to make a video in AfterEffects. The bottom there needs to be a margin. Is it possible to export the video with the margin being the white and gray square grid instead of it automatically turn white or black. I want this render to be the final render. I know how to do it so that when its brought into AfterEffects the background is gone, but I need the background to be gone on the QuickTime/AVI when viewing it on any video player, not just when editing in AfterEffects.
    Daniel Waldron replied 9 years, 6 months ago 2 Members · 1 Reply
  • Daniel Waldron
    March 9, 2017 at 2:05 pm
    So do you want the actual transparency grid in your final video or do you want to have a transparent alpha channel? If the first, just create a grid as a layer and export. If the second, you need to use a codec that supports an alpha channel like Quicktime Animation. Keep in mind that this creates a very large file and most non-professionals may not have the codec to play it back correctly.
    May I ask why you need this in a final deliverable? It’s pretty uncommon.
