Activity › Forums › Adobe After Effects › after effects 2022 how do i create astroid trail fire smoke
Posted by Jessica Chan on March 8, 2022 at 11:48 pmplease check attachment image.
how do i create this affect on element 3d layer.
check this image
Jessica Chan replied 4 years, 6 months ago 3 Members · 6 Replies -
Michael Szalapski
March 9, 2022 at 5:25 amYou would use a particle effect of some kind. After Effects has a number of them built in (like CC Particle World), but for something as complex as that, you’d probably want to turn to third party tools like Trapcode Particular.
Graham Quince
March 9, 2022 at 9:28 amI came up with a technique using CC Particle World for this:
https://www.youtube.com/watch?v=vtepOBF-oFc
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jessica Chan
March 9, 2022 at 10:49 pmi saw all your tutorials buddy.
the voice-over is funny and cool and a very friendly person thanks.
please share your projects and make some orb tutorials earth Collisions not one can be found on youtube.
this is exactly what i want but dont know how to connect this to my element 3d layer
Jessica Chan
March 10, 2022 at 2:36 amneed little help.
i tried applying particular trapcode but then element 3d hides below.
anyways i added trapcode P to a solid selected the 3d null of element 3d it follows but the particles are just in 1 strait line rather then emitting from particles from element 3d astroids
Michael Szalapski
March 10, 2022 at 4:06 amThey will be separate layers. Don’t put Particular and Element on the same layer.
You’ll have to get clever about how it works. Once you get it looking the way you want, you may need to duplicate your layer of Particular and put one below and one above the E3D layer and use the distance visibility settings to trim them to show up where they’re supposed to.
Alternatively, you can use a depth pass from Element and have one copy of Particular above the main E3D layer.
As to getting them to look like they’re emitting from the asteroid/comet/meteor, just a spherical emitter will probably do the trick, but you can also load 3d objects into Particular as an emitter source.
Jessica Chan
March 10, 2022 at 11:50 pmAs to getting them to look like they’re emitting from the
source.can you share a simple project element 3d astroid explaining the above i am eager to learn and see please micheal?
