Activity Forums Adobe Encore DVD after effects 16:9 comp to encore problem
  • after effects 16:9 comp to encore problem
    Posted by Hugo Ferreira on November 8, 2011 at 10:11 am
    I’ve got a 1024×576 SQ pixel comp made in after effects and used dynamic link to put it in encore, I preview it in encore and everything looks fine. Encore recognizes the 16:9 asset by showing the 16:9 check and if I would like to change it 4:3 I couldn’t. But when I burn the dvd and watch it in both the computer and a 16:9 TV flat screen it shows black bars on the left and right sides and is missing the information there, it’s literaly cutting it and showing a 4:3 image.
    Should I export the comp instead of using the dynamic link? Am I missing something?
    I usually use DVD Studio Pro and never had this problem but now I really have to use Encore.
    Any help is very appreciated.
    Thanks in advance
    Hugo Ferreira replied 14 years, 10 months ago 2 Members · 2 Replies
  • Chris Tompkins
    November 14, 2011 at 1:25 pm
    Well try rendering it out of AE first.
    Take file into AME to create the mpeg file.
    Import into Encore.
    Chris Tompkins
    Video Atlanta LLC
  • Hugo Ferreira
    November 14, 2011 at 5:47 pm
    Hi Chris, thanks for your reply.
    I already did that and it’s definitely better but I still have a problem. The image is in 16:9 on the tv but it’s scaled in a little bit. I’ve tried AME to Encore and also Compressor to DVD Studio Pro and the result is the same. I exported from after effects to a dv pal wide screen file. Should I export to a normal dv pal file without the wide screen?
