Activity › Forums › Adobe After Effects › After Effect Scale or resize image or video footage
  • After Effect Scale or resize image or video footage
    Posted by Albert Cast on June 22, 2015 at 12:01 pm
    I’ve been trying to find some kind of a shortcut I can use to scale down
    images or video footage that I drag into my main composition without changing
    the actual structure of the image or video. for example, in photoshop I use:
    Shift and the mouse to scale the image down to auto preserve the image structure.
    I hope to be understood.
    Albert Cast replied 11 years, 2 months ago 2 Members · 2 Replies
  • Daniel Waldron
    June 22, 2015 at 4:24 pm
    Are you talking about preserving the aspect ratio of the clip? Shift+click should work in After Effects too. Or select your layer in the timeline and hit the “s” key to open the scale options, making sure the little chain-looking “constrain proportions” button is turned on.
  • Albert Cast
    June 25, 2015 at 11:23 am
    Hey Daniel, Thank you!
    I was trying exactly the same like in photoshop, but was not working…
    But I tried just now in a very slowly way and it worked!
    Thank you very much for your help.
