Activity › Forums › Adobe After Effects › After Effect problems on x64.. Please Help..
  • After Effect problems on x64.. Please Help..
    Posted by Dominic Julian on November 6, 2008 at 10:39 am
    Hii.. I hope anyone can help me..
    I just instaled windows X64 and RAID storage to boost up performance in after effect, but the result is not what im expected.. In after effect the multi-processing option can’t be activated and its often to failed on render
    This is my comp spec :
    Intel Core 2 Duo 6400 @ 2.13hz
    6GB DDR2−667
    NVIDIA GeForce FX 7300 256 mb
    2 x 640GB 7,200rpm SATA 32MB Cache (RAID Storage)
    Windows XP Professional x64 Edition on separate drives for dual boot
    Any ideas what is wrong in my setting and technical spec??
    And what should i do?
    Thanks a lot..
    Jan Sherlink replied 17 years, 10 months ago 2 Members · 1 Reply
  • Jan Sherlink
    November 7, 2008 at 12:18 am
    that shouldn’t have anything to do with XP64
    and since you have enough ram to feed 2 processors, it should work…
    if you open the taskmanager (CTRL+ALT+DEL) does it show 2 processors ?
    cya,
    Jan
