Activity Forums Adobe After Effects After Effect Mask Path
  • John Cuevas
    January 26, 2012 at 5:10 pm
    If you created the cube in AE or it’s an object with an alpha channel.
    Take your cube and use the mask tool to divide it into the shapes you want-using multiple masks. You will find that overlapping the masks a few pixels will make this project easier.
    Now for each mask you created, duplicate your layer. IE..3 masks means you need 3 layers. Now open the masks and delete all but one mask for each layer. Layer 1 = Mask 1, Layer 2 = Mask 2, Layer 3 = Mask 3…
    Now you can animate each seperate layer to break apart your cube. I created a sample project for you. 3586_cubeexample.aep.zip
    I think you would find much of the information on this page beneficial.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Isaac Tallack
    January 26, 2012 at 6:41 pm
    In your example, how did you make all the masks fit perfectly?
  • John Cuevas
    January 26, 2012 at 6:51 pm
    I didn’t, I slightly overlapped each mask. Since the overlap is slight and the animation only 1 second, you really can’t tell that the pieces wouldn’t perfectly fit together.
    IF you go the route of using exact masks. I would change the transfer modes of each layer to alpha add.
    Thinkck.com
  • Isaac Tallack
    January 26, 2012 at 10:06 pm
    Thanks so much, I’ll be sure to come back to you if I ever need anymore help. You obviously know what you are doing 😉
  • John Cuevas
    January 27, 2012 at 1:08 am
    Just glad I could help. Have to say if I know anything it’s cause of the extremely helpful people here and great resources here at the Cow(and VideoCopilot.net too)
    Thinkck.com
