Activity Forums Adobe After Effects after effect keyframing problem
  • after effect keyframing problem
    Posted by Allen on July 8, 2005 at 4:07 am
    don’t know if these problem happen to any other AE user, its happen to me a lot with key frame.
    I’m animating in AE 3d envoriment with a still 3d camera, other objects are 3d and link to a 3d parent and usually I just animate the parent instead of the camera and some how I can’t get the animation to freeze in the timeline for sec and resume the animation afterward.
    For example I put a 1st keyframe at 1st sec and have object to pan and zoom and set other 2nd keyframe at 4th sec and I want it to stop for a sec so in the 3rd sec I put the keyframe which is same as the 2nd keyframe and in the 5th sec I put another keyframe to have it keep to move and zoom
    instead of that it does zoom, move back, stop and keep zooming, those weird movement a driving me crazy, I try toggle frame instead of normal keyframe it dosn’t work and I’ve try linear keyframe setting but still does the same thing.
    please help
    Cheers
    Allen
    X-claim replied 21 years, 1 month ago 2 Members · 1 Reply
  • X-claim
    July 8, 2005 at 4:31 am
    It sounds like your keyframe interpolation is bezier. To find out right click on the keyframe and go to ‘Keyframe Interpolation’, the setting you want is linear.
    Alternatly you could use a ‘Hold keyframe’ which is found in the same menu.
    Hope that helps
