Activity Forums Adobe After Effects After effect frame buffer during render
  • After effect frame buffer during render
    Posted by Legend on July 20, 2006 at 12:03 am
    I am rendering a project that is 35 sec. long in the animation codec 8 bit uncompressed. The comp has various size psd files. When rendering It stops and I get the message cannot create image buffer 720×486 can any tell me what is wrong I have a very crusial project and this rendering problem made me miss my slot. Any advice I really need help.
    Nicholas Toth replied 20 years, 1 month ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    July 20, 2006 at 3:27 am
    You may need to finetune your memory settings to purge your buffer more frequently.
    Press the Shift key and mouse over to the menu to select Preferences. Keep the Shift key down at all times. Select Preferences with the Shift key still down. Once you’re in the preferences dialog, select the drop-down menu, if you are still holding the Shift key down, you will see an option for Secret (or Scheret – depending on the version of AE). Release the Shift key and select the aforementioned preference.
    In its dialog window, set memory to purge every 5 frames. Restart AE and give the render another go. Your last option, if the above fails, is to set AE to purge its memory buffer each frame – value of 1.
    If all of these fail, then you may have some plugin issues. So let us know what plugins you have that may cause this issue. You’ll want to check the Websites of the plugins that you own to see if they have updated versions.
    HTH
    Roland Kahlenberg
    https://www.broadcastGEMs.com
    customizable animated backdrops with Adobe After Effects project files
  • Nicholas Toth
    July 20, 2006 at 3:33 pm
    I have mine set to 1 at all times before I render, it takes more time but the render’s failure rate is much lower….
    Toggle it before you set up the queue.
