Activity › Forums › Adobe After Effects › After effect CS5 crashes at launch!
Posted by Marie Stuart on October 12, 2010 at 6:14 amHi,
After effects keeps crashing while lauching. Here is the alert message :I saw that there was a lot of posts in various forums describing a similar problem, but the solutions and alert message seem different in each case… And I am really confused.
I hope someone can help !
Todd Kopriva replied 15 years, 3 months ago 5 Members · 6 Replies -
Walter Soyka
October 12, 2010 at 12:25 pmWhat solutions have you tried?
I haven’t had this problem before myself, but the solution I’ve seen posted a couple times is opening your home folder (Finder > Go > Home, or Cmd-Shift-H in Finder), then navigating to Library > Preferences > Adobe > After Effects and trashing the 10.0 folder.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Todd Kopriva
October 12, 2010 at 4:52 pmHave you installed the After Effects CS5 (10.0.1) update? That update fixes a lot of problems.
Also, see this page, which contains an explanation and solution for one common cause of the message that you’re seeing:
https://kb2.adobe.com/cps/857/cpsid_85711.html———————————————————————————————————
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Marie Stuart
October 13, 2010 at 7:12 amActually yes, just after sending this post, I installed the update and the problem was immediately solved.
Thank you anyway ! -
Marie Blochlaine
October 13, 2010 at 7:32 amActually yes! just after sending this post I installed the update and it solved the problem immediately.
Thank you anyway -
Declan Zimmermann
June 9, 2011 at 5:32 pmHello,
I am having precisely this problem.
What seems to have fixed it for others is the upgrade to 10.0.1.
Unfortunately, I have not been able to install the upgrade, as documented in Adobe Forums here:
https://forums.adobe.com/message/3566802#3566802
… where my message has not been responded to since my posting several months ago.
I am hoping Todd, who answered in both places will be able to help.
Thank you.
Declan
Todd Kopriva
June 9, 2011 at 6:12 pmTry uninstalling, then reinstalling, and then apply the 10.0.2 update.
