Activity › Forums › Adobe After Effects › after effect chroma
after effect chroma
Posted by Laurent on April 30, 2005 at 10:19 amWhat is the best way to do a chroma in the after effect?
ThanksSteve Roberts replied 21 years, 5 months ago 4 Members · 3 Replies -
Rusty Bridges
April 30, 2005 at 12:03 pmIf you’re using a blue background (for instance) go to effects, keying, color key. Use the eyedropper to get the exact same blue your chroma is. Put color tolerance to 100% Tada!! now you`re a jedi fighting in Star Wars.
Barend Onneweer
April 30, 2005 at 12:31 pmActually… the Color Key is a very primitive and crude effect. If you have the Pro version of AE 6.0 or 6.5, it comes with Keylight (separate installer from the CD), which is a very good tool for removing blue or green backgrounds. The documentation that comes with it is very helpful in explaining how to approach a chromakey.
Bar3nd
Forum COWmunity leader for:
ADOBE AFTER EFFECTS
MAGIC BULLET SUITE
INDIE FILM & DOCUMENTARY -
Steve Roberts
April 30, 2005 at 12:53 pmIndeed.
But if your chromakey is reeeeeally good (heh) you can apply Color Key many times to the layer, keying out a slightly different shade of blue with each application.
But if you have hair, spill, transparency, then you gotta get keylight. 🙂
Steve
