Activity › Forums › Adobe After Effects Expressions › After Effect Checkbox Color Control Fill
  • After Effect Checkbox Color Control Fill
    Posted by Costel Letsoc on January 19, 2018 at 4:53 pm
    I have an issue and I can’t seem to figure out what to do … and getting some expression errors
    Want to create a list of 5 Checkbox list that has assigned an individual colour assigned to it and using and Adjustment Layer to control the Fill Color of an Highlighted Text
    temp = thisComp.layer(“Adjustment Layer 4”).effect(“Color Control”)(“Color”); is assigned to a Text Layer/ Range Selector that Changes the Fill Colour
    I want to change that respective Colour using Some Checkboxes.
    Thank you,
    Dasher Mokum replied 7 years, 3 months ago 3 Members · 3 Replies
  • Kevin Camp
    January 19, 2018 at 6:26 pm
    you can’t really do it with checkboxes… you will encounter logic issues when trying to execute expressions that are dependent on other expressions.
    you can do it with a slider, so 1 would be a color, 2 would be another color, etc…
    also, unless you like writing colors in rgb values, i would keyframe the colors you want in the color picker, then use an expression on that color control to the value.
    so if you add a sider expression control to your layer, the expression for the color control could look like this:
    n = effect(“Slider Control”)(“Slider”) ;
    key( Math.floor( clamp( n, 1, numKeys ) ) ).value
    [edit]
    i just tested it and you can omit the Math.floor bit… so this works for the last line:
    key( clamp( n, 1, numKeys ) ).value
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Costel Letsoc
    January 19, 2018 at 10:47 pm
    Thank you very much for your help I’ve managed to do it this way, it works!
  • Dasher Mokum
    June 18, 2019 at 11:16 pm
    Hi Kevin,
    Nice expression and I got it working. But I am looking for the next solution for this. I’ve got a precomp with a text layer & Color control layer, this one is nested inside the main comp.
    Is it possible to put a color control layer in the main comp and link that to the text layer in the precomp?
    Cheers
