Activity Forums Adobe Premiere Pro After Duplicated a Sequence, new one is Un Rendered
  • After Duplicated a Sequence, new one is Un Rendered
    Posted by Andrew Stone on February 2, 2010 at 5:24 am
    I have a pretty long, pretty rendered sequence, and when I duplicate it to cut up a smaller clip of it, everything goes to be unrendered.
    Ive edited over 30 of this same type dvd, and have done it the same way on CS3, and this is my first on CS4, and although it sounds like a small problem, it is a huge time waster.
    I am hoping there is a simple menu selection I overlooked. I tried searching for a solution, but render searches seem to just bring up cross project related questions. So I turn to the experts.
    http://www.somethingmisleading.com
    Andrew Stone replied 16 years, 7 months ago 2 Members · 2 Replies
  • Vince Becquiot
    February 2, 2010 at 5:20 pm
    In CS3, all sequences had to be of the same type, and rendered files could be shared between sequences.
    This is not longer the case, each sequence can have drastically different settings, so they are automatically assigned new render files.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Andrew Stone
    February 3, 2010 at 3:34 am
    Thats a cool feature and all, but double render times is definitely a step back in both times and space. Is there a way to make it so a exact same sequence, doesn’t need to be rendered twice? Or a way to locate render files?
    Andrew
