Activity Forums Adobe After Effects After drawing a mandala path with Particular, is it still possible to keyframe its shape properties?
  • Kalleheikki Kannisto
    June 14, 2018 at 6:28 am
    You will have to adjust the formula and re-render. But you might even be able to render the whole shape in one frame, which would give you the result you’re after. If not, there’s always time remapping.
    Senior Graphic Designer
