Activity › Forums › Adobe Premiere Pro › After 7.2 update auto sync using audio no longer works.
Posted by Dennis Tzeng on December 19, 2013 at 7:30 amUpdated my Adobe CC which included Premiere Pro CC 7.2
Now when I try to auto sync clips using audio, it doesn’t work anymore. It actually throws the clips on opposite ends of the timeline.
Anyone else running into this problem?
I’m running it on a Windows 8.1 machine.
– Dennis
Peter Gudmunson replied 11 years, 7 months ago 5 Members · 5 Replies -
Jeremiah England
June 6, 2014 at 4:06 pmI have the same problem. About half the time it works great, the other half the time it acts like it synced it correctly, no errors shown, but it throws one of the clips about 20 minutes forward in the time line and leave the other where it was. Really bazaar.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Eric Monroe
July 16, 2014 at 4:32 pmI always had good luck until we updated to the CC 2014. I have 3 Macs and 1 Win7 machine….it seems that moving from CC to CC2014 caused this very same issue for all our machines.
Does anyone have any news as to whether this is being fixed or is even known?
syncing dslr clips to audio is a real nightmare the old fashioned way 🙁
Please advise
Eric
Kyle Bentley
August 7, 2014 at 2:41 pmFor some weird reason if you press synchronize again (after its thrown your clips apart) it syncs them perfectly, still gota put your displaced clip back to where it was on the time line but at least it syncs it!
Peter Gudmunson
January 7, 2015 at 8:04 pmThanks for this. To add to kyle’s workflow, if you have multiple audio clips that you’re trying to sync, the first clip you sync will lose its spot upon syncing the next one. I found that adding a marker on the video that lines up with the end of the first audio clip is an adequate workaround. It’s certainly not perfect–if you try to group the first synced audio with the video, and then attempt to sync a new audio clip to those, the synchronize option is grayed out.
