Activity Forums Adobe After Effects AF error
  • Posted by Russ930 on December 13, 2006 at 12:17 am
    I am getting this error when I try to send to Render Queue.
    After Effects Error: This Module does not support getting output suffixes
    (39::96)
    Can anyone help me out.
    BTW I am using Toonificate 3.0
    Russ930 replied 19 years, 9 months ago 2 Members · 4 Replies
  • Steve Roberts
    December 13, 2006 at 12:40 am
    More info please, specifically:
    Render codec?
    Frame size?
    Other plugins?
    Full output module info?
    Did you try rendering with all effects off?
    Did you try rendering with all layers off?
    What else have you done to troubleshoot this, and what was the effect?
  • Russ930
    December 13, 2006 at 1:10 am
    Render codec?
    Frame size?
    Other plugins?
    Render Setting
    Best
    Full
    720×480
    No Proxies
    Current Setting
    Read Only
    Output Module: Lossless
    How do I render with either effects or layers off?
    I don’t have any experence with AF so I am kind of lossed in troubleshootin
  • Steve Roberts
    December 13, 2006 at 1:40 am
    You can temporarily disable effects for a layer by hitting the f button for the layer.
    You can temporarily switch off a layer by hitting the little eyeball in the timeline.
    The render codec appears in the output module. Quicktime? DV? None? Animation?
    (for more info, check the help)
    Are you on Windows, OSX, Intel Mac?
  • Russ930
    December 13, 2006 at 1:55 am
    Quicktime
    OSX
    I kept messing around with the out put modules and I got it to work.
