Activity Forums Panasonic Cameras AF-100 not spanning clips across cards
  • AF-100 not spanning clips across cards
    Posted by John Bollenbacher on November 27, 2012 at 3:20 pm
    Hey All,
    I have an AF-100 and for some reason it won’t span clips across cards when one card gets full. I have relay record on, which I think, I think, needs to be on to have spanning; but when a card fills up it just stops recording and says card is full. Anyone tell me what I’m doing wrong?
    John Bollenbacher
    10engines
    Thomas Alexander replied 13 years, 7 months ago 3 Members · 2 Replies
  • Erik Naso
    November 28, 2012 at 6:16 pm
    This happened to me last week and I couldn’t figure out why. Reformat the cards in the camera next time and see if it happens again.
    I think I might have put the second card in the camera when the camera was already powered up so maybe that had something to do with it.
    Blog https://www.eriknaso.com
    My Vimeo Page https://vimeo.com/user626030
    Follow me on Twitter @ErikNaso
  • Thomas Alexander
    January 26, 2013 at 11:57 am
    The camera as far as i know cannot record more than 12 hours continuously even if the relay function is ON. The longest possible recording time with this camera is 12 hours and cannot be extended even if the relay function is used. That might be the problem. But logically if you had the relay function on it should have spanned. Mine does. Did you update the firmware? Other thing is that if you use two different types of SD cards maybe that is the reason.
    Thomas Alexander | Independent Cinematographer
    Soulman Films | Nicosia Cyprus | +357-97697640
