Activity › Forums › Adobe Premiere Pro › ?Should I Buy RAM w.o. a CUDA GPU
  • ?Should I Buy RAM w.o. a CUDA GPU
    Posted by Peter Tours on December 8, 2012 at 6:12 pm
    Need advice – can upgrade my 16gb to 32gb at a reasonable price – will it really make a big diff w.o. CUDA GPU?
    P2 1080i, PPCS6 2010 Mac 12 core… I don’t “just edit”, I finish.
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    TRI EA5 1974-1977
    Convergence ECS1B 1977-1979
    Sony BVE 500 1979 – 1984
    Datatron Vanguard 1984 – 1993
    GVG VPE141 1993 – 1998
    Media 100 1995 – 2006
    Final Cut Pro 2005 to not too much longer
    Adobe Creative Cloud
    Alex Gerulaitis replied 13 years, 9 months ago 2 Members · 3 Replies
  • Alex Gerulaitis
    December 9, 2012 at 10:20 pm
    Check your memory usage while you’re editing. On OSX, you can use Activity Monitor. If memory usage gets close to the limit, and the system seriously slows down – then yes, memory will likely be a more feasible upgrade. Otherwise – the GPU.
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
  • Peter Tours
    December 9, 2012 at 10:36 pm
    Thats exactly what is happening . 15.96 gb out of 16gb yellow, active. I assume that means its also using my hard drive, which really slows things down. I went ahead an ordered the ram since the investment was much less than a gpu..so now I will have 32. Unreal!
    Peter Tours
    Fort Lauderdale, FL
    TRI EA5 1974-1977
  • Alex Gerulaitis
    December 9, 2012 at 10:40 pm
    [peter tours] “Thats exactly what is happening . 15.96 gb out of 16gb yellow, active. I assume that means its also using my hard drive, which really slows things down.”
    Yes, when memory gets full, the systems starts offloading chunks of memory to the hard drive, and that is a really slow process.
    [peter tours] “I went ahead an ordered the ram since the investment was much less than a gpu..”
    Good call.
    Alex Gerulaitis
    Systems Engineer
