Activity › Forums › Blackmagic Design › AES/EBU input on M/E 1
Posted by Jim on February 2, 2013 at 8:08 pmI see that the TV version of the switcher has an BNC AES/EBU input. Can you input an AES/EBU signal into the M/E1? If so could you walk me through the set up?
JimJim replied 13 years, 7 months ago 4 Members · 4 Replies -
Justin Strauber
February 3, 2013 at 10:47 amThe TVS is the only one with an AES/EBU input. The 1M/E only has analog audio inputs. One stereo and one LTC. Same for the outputs.
The 1M/E, however, will accept two channels of embedded audio per input, and all of the SDI / HDMI outputs include that embedded audio.
Bob Zelin
February 3, 2013 at 1:51 pm1. Purchase behringer aes to analog converter
2. Put aes audio into behringer, and converted analog audio into atem
3. Go have a beerBob Zelin
Matt Drabick
February 3, 2013 at 2:40 pmJim, I sell the Blackmagic ATEM products . . . I have the Behringer Analog to AES converter and BNC adapter in stock. Call me at 919 790 5488 . . . .
Matt Drabick,
DigiTek Systems
Raleigh,NC -
Jim
February 8, 2013 at 1:56 pmThanks for your inputs. The reason I asked about the AES was because our analogue audio DA was being used up and we still had several AES outs doing nothing. We worked it out.
Cheers,
Jim
