Activity Forums AJA Video Systems AES to analog conversion for Kona 3
  • AES to analog conversion for Kona 3
    Posted by Andrew Dietz on September 10, 2009 at 7:15 pm
    I just purchased a Kona 3 card, but my mixer doesn’t have AES inputs for monitoring. I could change the output in FCP to line out, but I have to do this everytime, or I would have to create easy setups for everything. Does anyone know of a good converter or other workaround that will do the trick? Many thanks.
    I found this Miranda converter:
    https://www.miranda.com/product.php?l=1&i=144
    But it looks like it is around $650. Maybe I should look into getting a new mixer…
    Doug Beal replied 17 years ago 4 Members · 5 Replies
  • Andrew Dietz
    September 10, 2009 at 7:40 pm
    Lucky me…
    I found we had 2 Flying Cow converters laying around that do this exact thing. 1 more device I have to deal with now as If I don’t have enough equipment around me!
  • Bob Zelin
    September 11, 2009 at 1:58 am
    I guess that all my smart ass answers all come from seeing the same type of post over and over and over AND OVER again.
    Uuuuuuggghhh Duke – the recommended breakout box from AJA (AJA K3 box) for the Kona 3 has analog outputs for $258 street price.
    Bob Zelin
  • Jeremy Garchow
    September 11, 2009 at 3:52 am
    You get your Kboxes on the street?
    Wow, what a fantasy land you must work in.
  • Andrew Dietz
    September 11, 2009 at 4:27 pm
    I saw that the K3 had analog outputs, but I assumed it was expensive. Of course AJA doesn’t have prices on their site. But I googled it later and found it. I’ll see if I have any sync issues with the Flying Cow before I invest in the K3.
    If it makes you feel better, I googled AES to analog conversion and researched stuff for like 30 minutes before I even posted. But I don’t mind smart ass responses so post away.
  • Doug Beal
    September 16, 2009 at 9:02 pm
    used a flying cow for a long time with no problems now they are no longer manufactured.
    I’m now using a few Behringer SRC2496
    also handy for analogue input from mics etc.
    I lock it to AES from the Kona3 which is locked to black or tri level
    they run about $199 most online stores
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
