Activity Forums Adobe After Effects Expressions aerender and expression (JSON)
  • aerender and expression (JSON)
    Posted by Vitali Virulaine on January 11, 2021 at 4:07 pm
    I’ve created an expression for text title using:
    myData = footage(“data.json”).sourceData;
    myData.title
    It’s working when I see the preview, but when I try to render it using aerender then it shows default title.
    Is there anything that I need to do? precompile somehow?
    When I set text using expression then it’s not changing if I render comp using aerender:
    myData.title
    If I render comp using After Effects then it’s displayed correctly.
    I use command:
    /Applications/Adobe\ After\ Effects\ 2020/aerender -project /Users/user/Desktop/test.aep -comp Insta_1080x1080_01 -output /Users/user/Desktop/sm.mov
    Thanks for any help!
    Vitali Virulaine replied 5 years, 7 months ago 2 Members · 2 Replies
  • Fabrice Leconte
    January 11, 2021 at 4:37 pm
    Hello,
    I think you need to add your JSON file into your composition.
  • Vitali Virulaine
    January 11, 2021 at 4:52 pm
    Oh, thank you Fabrice! It worked!
