AE/Premiere Footage looks wierd
I have a project that was shot on the same camera…with one caveat…The first set of footage was recorded on a nanoflash, the second set on camera. It i s a jvc hm790. I am editing in primere, I normally use FCP, but this requires a lot of AE embedding. It has some tricky keys and keylight is the best I am finding to do them. so all the green screen are linked AE comps. The footage from Nanoflash looks fine. The camera footage looks jittery. Both look fine in FCP playback. When I render the camera footage audio seems out of sync because of this jitter. It is not, I can go frame by frame and see the hits on B’s and P’s. Both are supposed to record XDCAM EX @ 35mbps. Does anyone know what is causing this, and better, a solution?
Rich Kaelin
Kaelin Motion Production Services
https://kaelinmotion.com
New York
