Activity Forums Adobe After Effects .aep projects default application problem
  • .aep projects default application problem
    Posted by Chris Mathews on July 17, 2016 at 10:57 am
    I installed After Effects CS4 on brand new computer and everything was fine, then i remembered that I have some old projects created in After Effects 7.0, so I installed the 7.0 version. Now when I try to open the AEP projects the default is After Effects 7.0, even when right click – open with – after effects CS4, I got After 7.0 starting. I tried changing the default opening program, but when I select CS4, navigate to program files/etc. it goes back and only After 7.0 is showed.
    Chris Wright replied 10 years, 2 months ago 2 Members · 4 Replies
  • Chris Mathews
    July 17, 2016 at 4:19 pm
    Windows 7 32 Bit, I had them on a previous machine and they worked with no problem.
    I tried opening the projects via open file and they are working fine, in fact the whole application is working fine, the only problem is opening the projects directly with double click.
  • Chris Wright
    July 17, 2016 at 5:03 pm
    it should fix with hold down right shift then right click open with, browse to application-check box always open with.
  • Chris Mathews
    July 17, 2016 at 6:17 pm
    I cant select CS4, because when I select the app it goes back to the menu where only is 7.0 Icon and it says Adobe After Effects.
  • Chris Wright
    July 17, 2016 at 10:47 pm
    i don’t want to post a registry edit here so google “user choice registry”
