Activity › Forums › Adobe After Effects › .aep is not a valid Win32 application??? HELP
Posted by Sean Tatalovich on September 28, 2007 at 4:32 pmI can’t open AE saved files. It says:
.aep is not a valid Win32 applicationI can only open them from within AE. Can anyone explain this? Also my AE saved files have no icon.(.aep)
Sean Tatalovich replied 18 years, 11 months ago 3 Members · 5 Replies -
Rob Webster
September 28, 2007 at 5:55 pmIt sounds like Windows has forgotten the file association. Right click on the file, then in the fly-out menu, go down to Open With…. If After Effects isn’t an option there, there should be an option to Choose Program… at the bottom. Find your After Effects executable file, check the box that says some like “Always use this program to open this type of file”, and you should be good to go.
David Frisk
September 28, 2007 at 6:59 pmI have the same problem on my computer. I’ve tried doing what you’ve suggested, both by picking AE from the open with menu and choosing the executable from “Choose Program”. But after choosing it, the same error message comes up. Weird really.
Sean Tatalovich
September 28, 2007 at 7:30 pmHi Rob I already tried that. I even went into folder options to see if I could even make the icon a AE icon and that didn’t work either.
Sean Tatalovich
October 3, 2007 at 4:30 pmI don’t know what to do. I have the Master collection is there a way to reinstall just AE?
Sean Tatalovich
October 7, 2007 at 7:45 pmFigured it out. Had to do complete reinstall. All better.
