Activity › Forums › Adobe After Effects › AEi CS5, 3D Camera – Grid not visable in real time
  • AEi CS5, 3D Camera – Grid not visable in real time
    Posted by Tom Hollis on September 19, 2010 at 4:03 pm
    I have just picked up AE CS5 for PC this week.
    Following the recent tutorial from visual copilot (https://www.videocopilot.net/tutorial/energy/) I noticed that after creating a new simululation>CC Particle World, and turning it’s Grid ON, then creating a new camera, when I move the 3D camera around, I do not see the grid move in real time, rather after I move the camera, the grid dissapears and the particle stays frozen, and after the move, it’s as if the camera DID move, only I can’t see it happen while I do it.
    Is there a setting I should have toggled to allow real time placement of the 3D camera?
    I should note that I’m using a relatively high end i7 machine with 6GB ram, and that I can move the composition in 2D space in real time without any hiccups.
    Cheers,
    Tom
    John Cuevas replied 16 years ago 2 Members · 1 Reply
  • John Cuevas
    September 20, 2010 at 3:00 pm
    Just tried it out and it seems the grid does turn off when you move the camera around.
    You could make a fake grid. create a large solid, apply the grid effect, turn it into a 3D layer and put it in the approximate place where the CC Particle grid/floor is located.
    Johnny Cuevas, Editor
    http://www.thinkck.com
