Activity Forums Adobe After Effects Expressions AECC2017 Script for “Slider to Opacity” trouble
  • AECC2017 Script for “Slider to Opacity” trouble
    Posted by Fabiano Noli on November 17, 2019 at 12:40 am
    Hi Community!
    I have a trouble with my script
    I use AEC2017 and I want that the opacity of my Precomp is “turned off” when my slider control is equal or less than 0,02
    So
    I used a Script of CreativeCow Brother that I found in this blog.
    And this script is:
    ctrl = thisComp.layer(“control”).effect(“Slider Control”)(“Slider”);
    if ( Math.floor( ctrl ) == 1 ) 100 else 0;
    In this case, with other value obviously, this script works great!
    And the mist started to disappear.
    But when I change that in this:
    ctrl = thisComp.layer(“Master”).effect(“Slider Control”)(“Slider”);
    if ( Math.floor( ctrl ) <= 0,02 ) 100 else 0;
    don’t works anymore
    Can You help me?
    Thank you for your time
    ps. I tried also these:
    -if(thisComp.layer(“Master”).effect(“Slider Control”)(“Slider”)<=0,02) 100 else 0
    -if(thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”)<=0,02) 100; else 0
    -if(thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”)<=1) { 100 }else{ 0 }
    Gonzalo Menevichian replied 6 years, 9 months ago 3 Members · 5 Replies
  • Dan Ebberts
    November 17, 2019 at 5:49 am
    Try this:
    ctrl = thisComp.layer(“Master”).effect(“Slider Control”)(“Slider”).value;
    ctrl <= 0,02 ? 100 : 0
    Note that I’m not sure about the 0,02 punctuation, here it would be 0.02
    Dan
  • Fabiano Noli
    November 17, 2019 at 5:18 pm
    Hi Dan,
    thanks for your time!
    Your script is great!
    It worked!!!
  • Gonzalo Menevichian
    November 17, 2019 at 7:46 pm
    Hi Dan
    I pretty Newby on the expression script I have this line:
    (thisComp.layer(“Slider”).effect(“Slider Control”)(“Slider”).value >= 50) ? 0 : 100;
    That it work well but I would like to add “if is <=10 or =>50” then ? 0 : 100;
    How Could I do that?
    G
  • Dan Ebberts
    November 17, 2019 at 8:02 pm
    Like this:
    s = thisComp.layer(“Slider”).effect(“Slider Control”)(“Slider”).value;
    (s <= 10 || s >= 50) ? 0 : 100;
    Dan
    November 17, 2019 at 8:08 pm
    OMG!
    It works!!!!
    Thank you so much!!!!
