Activity Forums Maxon Cinema 4D Aec II
  • Posted by Chris Smith on May 25, 2005 at 7:10 pm
    So I played around with importing Multi Pass renders in AE. You guys succesfully help me locate the AE plug-in and I did great tests. Now I am working on a real project. I’m doing a test multi-pass render and now the AEC won’t load into AE. Yet if I import the same AEC from my tests, it works great. I don’t think I did anything different. I actually selected ‘Add Image layers’ and put object buffer tags on a few objects. I have a folder full of the seperate QT’s and the .aec file. However when I import the .aec, nothing. It won’t take.
    Are there some gotchas I’m missing or is there a way to test what I am doing wrong?
    Chris Smith
    https://www.sugarfilmproduction.com
    Chris Smith replied 21 years, 4 months ago 1 Member · 1 Reply
