Activity Forums Adobe After Effects ae7 to CS3 projects not playing back
  • ae7 to CS3 projects not playing back
    Posted by Danny Perez-triana on August 28, 2008 at 9:33 pm
    i’ve run into a problem that seems to have come up in the forum before:
    https://forums.creativecow.net/readpost/2/915703
    unfortunately, i don’t see a remedy ever posted.
    i wondered if there was a way to directly contact this cowmember to see if they’ve since (a year ago) remedied this problem?
    the problem: AE7 projects playing back messed up in CS3. running a macpro 2.8. in the middle of a huge project so i had to upgrade systems but am still bound to these AE7 versions of the projects.
    when clips play back in timeline, they’ll stop moving as the timecode moves on. freeze in the middle of the frame.
    if i try to duplicate the work in another new project the same things happens eventually. videos freezing.
    so it seems that i must be able to remedy the situation within AE overall rather than something just being wrong with this project file?
    any help would be greatly appreciated,
    Ignacio
    Mark Hamilton replied 18 years ago 2 Members · 1 Reply
  • Mark Hamilton
    August 29, 2008 at 9:12 pm
    Did you happen to create your AE7 files using Windows? And are now using a Mac w/CS3?
    Also, what are your preview settings? (you’ll find them in the viewer/preview window > icon that looks like a monitor with a lightning bolt down the center).
    Mike
